pioneer avx-p7300dvd
storm27
Member - Posts: 6
Posted: June 29, 2005 at 3:00 PM / IP Logged
Ok, I have the unit and I know where each goes "that's easy" except one but how do you hook-up the parking brake wire to the the switch????  I am confused because the installation manual says I should hook the (green) wire to the 12-volt power supply side I guess and ground the other side.  could someone please explain the correct way to hook it up? I would really appreciate the help, thanks
storm27
Member - Posts: 6
Posted: June 29, 2005 at 3:02 PM / IP Logged
pioneer avx-p7300dvd -- posted image.
storm27
Member - Posts: 6
Posted: June 29, 2005 at 11:05 PM / IP Logged
This guy is done working on my pioneer avx-p-7300dvd player and I need to know a.s.a.p how can I bypass the parking brake wire to see if the dvd player does work, then if it works I will connect it to the parking brake switch.  Should I just connect the wire to power? Please, if you kow the anwser please respond and don't just view the topic. thanks
shiftmx11
Member - Posts: 27
Posted: June 29, 2005 at 11:09 PM / IP Logged
ground wire
shiftmx11
Member - Posts: 27
Posted: June 29, 2005 at 11:11 PM / IP Logged
do not connect to power just the ground
storm27
Member - Posts: 6
Posted: June 29, 2005 at 11:46 PM / IP Logged
thank you very much, I would hate to smoke my unit the 2nd time
methinfinity
Member - Posts: 36
Posted: June 30, 2005 at 7:26 AM / IP Logged
hook parkbrake wire from head unit straight to ground then you dont need to have park brake on to watch movies etc. if youre worried about it just wire it through a switch.
methinfinity a.k.a. tha methodist
storm27
Member - Posts: 6
Posted: June 30, 2005 at 3:29 PM / IP Logged
Can any one send me a detailed diagram of the wire harness? because pioneers diagram of the harness doesn't show where each wire is at in the plug. thanks pioneer avx-p7300dvd -- posted image.
Monday, April 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
