Gentex 346 Homelink/Dimming Mirror
Silverone1
Member - Posts: 24
Posted: February 08, 2006 at 3:40 PM / IP Logged
I am trying to adapt this mirror to a PT Cruiser.  It has a 10 pin connector (2 rows of 5) with orange, yellow, green and white wires.    The windshield mount is not wedge shaped, but square with rounded corners.    I searched here, but found nothing regarding this mirror.
Where can I get a connector to match the mirror and a wiring color code?
Is there a mounting adapter available to match the Cruiser's?
Silverone1
Member - Posts: 24
Posted: February 10, 2006 at 2:01 PM / IP Logged
OK   I'll ask a more basic question.  The 10 pin connector (2 rows of 5) must be commom to many Gentex mirrors.  Can anyone provide the pinout for the orange, yellow, green and white wires.  I searched here, but found nothing regarding this connector.
Thank you.
mo12v
Posted: February 10, 2006 at 3:33 PM / IP Logged
Try MITO Corp......1-800-433-6486............ www.mitocorp.com Tech Service
Does this have the Temperature Display also??
MO
Silverone1
Member - Posts: 24
Posted: February 10, 2006 at 5:38 PM / IP Logged
Thanks MO.     I had talked to a person at MITO and was told me they couldn't help me unless I bought the mirror there.
mo12v
Posted: February 10, 2006 at 8:54 PM / IP Logged
Are these the ONLY wires on the plug? ( orange, yellow, green and white wires )??
What vehicle did you get it out of?
MO
Silverone1
Member - Posts: 24
Posted: February 10, 2006 at 11:25 PM / IP Logged
There is a 10 pin connector on the mounting bracket.  Only 4 of the pins have wires that go inside the back of the mirror.
The only mirror functions are automatic dimming and Homelink buttons; there is no temperature or compass display.  I'm assuming that there is +12V, -12V, switched +12V and "maybe" a connection to turn off the dimming when in reverse.
The guy I got it from didn't know what car it came off of.  I had a windshield shop compare the windshield mounting adapter to those in a catalogue and determined that it could have come out of a Hyundai (Elantra,Sonata,Tiboron) or some Mitsubishi models.
mo12v
Posted: February 11, 2006 at 8:34 AM / IP Logged
Still checking..........
Is there Dome Lites on this mirror?
MO
Silverone1
Member - Posts: 24
Posted: February 11, 2006 at 11:23 AM / IP Logged
No, I don't see any dome lites.
Silverone1
Member - Posts: 24
Posted: February 17, 2006 at 10:38 AM / IP Logged
Anyone have any ideas on the pin out for this mirror.  The connector shows the following:  pin 6 white, pin 7 green, pin 8 yellow, pin 10 orange.
Does anyone know how to peal the mirror open without wrecking it, so the I can look at the connections on the PC board?  Maybe I can figure it out from there.
