2005 Golf TDI VSS wire location
dustind33
Posted: April 03, 2006 at 11:36 PM / IP Logged
Can someone help me find the VSS wire to tap into for an aftermarket navigation unit. I have been searching for a few days now and I have found some people listing a pin in the blue harness as well as the green harness behind the instrument cluster. I have also read that i can and cannot be found behind the radio if it has speed sensing volume (mine is supposed to).   And I have also read that I can tap into one of my ABS wires on the drivers side of the car behind the rear seat.
I am getting pretty confused!
Dustin
gus1
Gold - Posts: 1,013
Posted: April 06, 2006 at 11:46 AM / IP Logged
Pull either the driver's or passenger's rear side panel. You will see the harness that goes to the rear of the car over the wheelwell. There will be a twisted pair that exits, wrapped in black tape, be a colored and a black. THis is one of the ABS wheel speed sensors. Use the non black wire. You may need to diode isolate your wire to keep the ABS computer happy.
Gus
matt_uk
Member - Posts: 9
Posted: April 21, 2006 at 7:43 AM / IP Logged
Hi,
You can always use a CAN Bus interface, they are easy to install and avoids the potential dangers of tapping unknown wires.
