Initial CDS-160 DVD Player Power Issue
pioneer212
Member - Posts: 17
Posted: April 05, 2006 at 10:06 PM / IP Logged
I wanted to know if it would be ok to tap the + and - leads into a heater switch located next to the front seats of my 2004 Nissan Quest to power the standalone DVD player. I have already successfully been using an FM transmitter that is powered by the leads to the passenger heater switch.  Would it be ok to tap the heater to power the DVD player, or could that possibly casue a short becasue it is drawing to much power for the wire which is more or less 18AWG. The Specs on the DVD player is a 20 W power consumption. Thank You
Pioneer 212
whitenoiz
Member - Posts: 26
Posted: April 16, 2006 at 10:17 AM / IP Logged
If I was you I would run a stand alone power from the ignition harness and fuse it so as not to short out your heater wire. Also ground it seperately to reduce any chances of shorts or overloads!
pioneer212
Member - Posts: 17
Posted: April 16, 2006 at 3:12 PM / IP Logged
Are you saying that i should still use the + lead from the switch but fuse it and than not use the switch ground but another one.
Pioneer 212
whitenoiz
Member - Posts: 26
Posted: April 16, 2006 at 3:41 PM / IP Logged
Yes and no! I would run another power altogether. Preferably from the ignition harness. And yes to a seperate ground.
pioneer212
Member - Posts: 17
Posted: April 16, 2006 at 4:54 PM / IP Logged
As long as I fuse the + lead to the switch, I should be fine right?. If I find that the dvd player is overloading the heater switch wire I will then run a lead from the ignition. Thank You for your help.
Pioneer 212
whitenoiz
Member - Posts: 26
Posted: April 16, 2006 at 4:55 PM / IP Logged
No problem! Good luck!
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
