2006 Mustang brake switch?
dreem363
Posted: December 08, 2006 at 9:35 AM / IP Logged
Hey guys I just purchased a Jensen VM9311TS in-dash dvd stereo.  I have everything installed except the video.  I need help location the brake switch on my 2006 Ford Mustang GT in order to connect pink wire from stereo to that switch.  My car is a manual if that makes any difference.
Can any one help with locating this wire, any ideas what color the wire is?
Thanks for your help in advance.
KarTuneMan
Platinum - Posts: 7,056
Posted: December 08, 2006 at 5:26 PM / IP Logged
 BRAKESWITCH Green At switch above brake pedal   +
 PARKLIGHTS BLACK/ green At light switch harness   -
 HAND BRAKE RED / yellow At switch on handbrake lever   -
 HORN Blue At steering column   -
pjackson
Posted: December 26, 2006 at 3:47 PM / IP Logged
I got the same radio and the same problem...  I need help locating the brake switch on my 2003 H2 in order to connect pink wire from stereo to that switch.
Thanks in advance!!!!
Percy J
pjackson
Posted: December 26, 2006 at 4:56 PM / IP Logged
I may have answered my own question digging around on the internet.
(I strongly advise against driving and watching a DVD, but this info I found may be helpful to some of you that may have gotten a good deal on that jensen vm9311ts like I did and want to disable that parking brake feature:
Don't pay for it....Just read it:
The code is a permanent way of disabling the brake override on the jensen units.
There are two ways of doing this:
Insert the DVD
After the disc loads and plays you will see a blue screen telling you "it is unlawful to drive with a movie blah blah blah"
1)Activate the brake sequence and disable the blue screen using the hand brake, the switch method or anything else to give the unit its three pulses to disable that freakin blue screen.
(What I did was I installed my radio entirely, then took the pink wire and touched for two seconds, removed for two seconds and then touched and held the negative pole of a mower battery laying on my passenger seat until the screen was no longer blue.)
2) Next, on the main remote press stop twice, then 1, 2, 6, 4.
You will now see a hidden menu that says:
Region Code
Brake Override (I know you're drooling by now)
Macrovision (Watch all the burned and pirated movies you want if this option is off)
Loader Version
Model Version
3) Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want.
This is what you want:
Region Code: 1
Brake Override ON
Macrovision: OFF
When your done, click SYS SETUP on the main remote TWICE to save the settings and bingo, your done!!! Hooray!!! You can now kill your whole family in the car while watching that adult movie while your driving.....
The other way of doing this is by not engaging the parking brake sequence, thus you're inputting the code blindly.
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings.
It may take a few tries but you'll get it. This method can be done if you don't want to bother temporarily activating the brake sequence, but if you only have the unit and no additional tv's, its #$%^&* damn hardbecause you can't see the settings your changing.
I tried to make this as clear as possible. If you have questions, private message me or post here.
This code DOES work.
Best of Luck!
By the way, this is for informational purposes only and I will not be responsible for anything bad/stupid/ignorant you do with your Jensen unit.
Percy J
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
