wiring block identification
y2j514
Copper - Posts: 94
Posted: August 23, 2008 at 10:04 PM / IP Logged
I have a 97 sunfire 2.2 L engine.  Recently a wire has corroded and is causing MAJOR problems with the car - i.e. the engine won't run. (Starts but stops immediately).  Anyways I'm pretty sure this corroded wire is the problem...if not it still needs to be replaced.  I'm just not sure how to replace it because it corroded literally right at the end of the wire going into this block.  So my main question is does anyone know what this block is/ what its called, and how do you replace a wire right at the end.  Does it open up and I run a wire into it ? (Its the black wire thats corroded...its difficult to see in the zoomed in picture but I think u can get the idea.
wiring block identification -- posted image.
Platinum - Posts: 13,726
Posted: August 23, 2008 at 10:41 PM / IP Logged
On your digital camera, there is a picture of a flower. Set it to the flower setting. Re-take the close up picture and post it.   The flower symbol is the Macro setting of the camera, it allows the camera to focus on a close up object.
y2j514
Copper - Posts: 94
Posted: August 24, 2008 at 5:40 PM / IP Logged
Well I dont entirely think a slighty clearer picture will help.  If somebody needs one Ill definately get one, but it is mostly just to identify the box all the wires go in, so I know it it can be open or not.
reax222
Copper - Posts: 220
Posted: August 25, 2008 at 12:01 AM / IP Logged
Is there a bolt in the middle of it?
