blinkers not working
trishyg
Member - Posts: 8
Posted: January 27, 2009 at 11:25 AM / IP Logged
I installed a new car stereo last week & yesterday just noticed the blinkers aren't working.   BUT I was rear-ended on New Years eve also & last week the bumper & exhaust system were replaced. I don't know if maybe I wired the stereo wrong or if the auto shop had to d/c the blinkers and didn't reconnect??
ckeeler
Gold - Posts: 1,461
Posted: January 27, 2009 at 11:27 AM / IP Logged
do the front ones and the dash indicators blink?
trishyg
Member - Posts: 8
Posted: January 27, 2009 at 12:16 PM / IP Logged
nope, nothing
ckeeler
Gold - Posts: 1,461
Posted: January 27, 2009 at 12:53 PM / IP Logged
if the same is true if you try the hazzard switch as well, you probably have a circuit with an open fuse. you'll have to start checking the fuses. if hazzards work, replace the turn flasher as it probably went out. hazzard and turn flashers are usually separate.
ckeeler
Gold - Posts: 1,461
Posted: January 27, 2009 at 12:54 PM / IP Logged
and BTW, what year, make and model?
trishyg
Member - Posts: 8
Posted: January 27, 2009 at 12:58 PM / IP Logged
yeah sorry bout that. It's a 2004 Subaru Forester and the hazards aren't working either
trishyg
Member - Posts: 8
Posted: January 27, 2009 at 1:04 PM / IP Logged
Also, to replace the stereo in that car ya have to take apart the whole middle part of the dash & console..maybe I knocked something loose? lol Gonna have hubby check the fuses, but he's adamant that the repair shop did something.
trishyg
Member - Posts: 8
Posted: January 28, 2009 at 11:35 PM / IP Logged
fuses are fine...
Platinum - Posts: 13,726
Posted: January 29, 2009 at 5:33 AM / IP Logged
Is the hazard switch mounted to the bezel that surrounds the radio?  If so remove it and make sure the hazard doodiech is not unplugged.
Posted: February 04, 2009 at 5:09 PM / IP Logged
It's noot a doodiech its a fromigawhatsijamacallit, you know that white molex or amp plug that if you don't lock in all the way especially on Toyotas fails to work.
