1990 Chevy Beretta
matkt1108
Posted: June 11, 2002 at 11:26 AM / IP Logged
I have a 1990 Chevy Beretta and when i step on the brakes it takes up alot of power (i know this b/c i have the gauge on the inst. cluster) also when i come to a complete stop the power that it producing goes from about 13 volts to 11 volts. the battery and alternator are brand new. how can this be stopped.
jtneis
Posted: June 14, 2002 at 10:16 PM / IP Logged
i too have a 1990 beretta and it used to be when i turned on my turn signals the voltage we drop with each blink. there are two things you can do. Either step up your alternator to a higher amperage or what i did to solve the problem, which is buy an optima yellow top battery.
bberman1
Gold - Posts: 2,314
Posted: June 15, 2002 at 1:32 AM / IP Logged
Do you have an internal or external voltage regulator? If the regulator is not built into the new alternator, I would replace the external voltage regulator and see if it helps.
super chev bere
Posted: August 25, 2002 at 3:36 PM / IP Logged
you need a bigger batt more cca cold cranking amps
witch will stop the alt draw you have
heavy chevy
