car stereo in my house
frankm1960
Posted: December 09, 2011 at 12:09 AM / IP Logged
Hi,
I have an old kenwood car stereo which I would like to use in the house. It's a 1999 CD/Rx model KFC 215S.
If anyone here could offer some advice or helpful hints on how I could do this that would be wonderful car stereo in my house -- posted image.
Thanks,
Frank
Posted: December 09, 2011 at 4:08 AM / IP Logged
A pair of book shelf speakers and a stabilised power supply* delivering a minimum of 10 amps.
*Not a battery charger.
At which point you will find it cheaper to buy a home unit.
oldspark
Gold - Posts: 4,913
Posted: December 09, 2011 at 7:27 AM / IP Logged
x2.
frankm1960
Posted: December 09, 2011 at 8:32 AM / IP Logged
Thank you howie and oldspark.
I forget to mention I have two kenwood KFC S695 140W speakers which I bought with the stereo back in 1999, mounted in proper speaker boxes, nice heavy speaker wire and ready to go.
So what I need is a 10A , 14V, power supply which I'm guessing is costly.
Any easy way to test the system before I put it in the classifieds?
It hasn't been used since 2004.
limomanpaul
Posted: December 09, 2011 at 11:46 AM / IP Logged
Alpine 9831 Head unit: Can I use the power of the built-in amp to power to four front/rear speakers, and still use the sub out -puts to an amp that'sgoing to power two 12"s, without using any high-to-low level adapters or special plugs, just the RCA's ? Yes, the amp does have built-in crossovers, so does my amp.  And I still have in my garage............
And thank you, Oldspark, for the quick reply the other day.
Posted: December 09, 2011 at 1:44 PM / IP Logged
The new poster, yes you can use the head unit but for domestic use in your home you're going to need the amps power rating, say the fuse on it = 40 amps plus if the Alpine is a high power unit, say another 15 amps = a stabilised 60amps+ power supply = about $300!!!
frankm1960
Posted: December 09, 2011 at 3:59 PM / IP Logged
I just found out a 7A power supply will cost around 100 bucks.
So that's out.
Can I use power supply from a desk top computer? I have one here and it's a DELL Model HP-233SNF.
Here are the specs on the supply itself:
AC input(60/50Hz): 115V
DC Output:
+5v === /29A, +12v === /6A
-5v === /0.3A, -12v === /0.3A
MAX OUTPUT POWER: 230W +3.3V=14A
FUSE RATING: T6.3A/250VAC =5VFP=1.2A
Seems like a long shot... but any ideas if this might work.
I don't see a power button on the supply anywhere either. Tons of cables/wire harnesses plugged into it. Long shot for sure, at least for me car stereo in my house -- posted image. I'm already way in over my head here car stereo in my house -- posted image.
Posted: December 09, 2011 at 4:28 PM / IP Logged
Which is about 7% of the power you will need.
This thread is so pointless.
Tuesday, April 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
