windows, 1987 town car
cherokeeram
Posted: July 01, 2013 at 2:14 PM / IP Logged
I have a 1987 Lincoln Town Car and none of the window controls work except one.  The main controls on the drivers door only activates one of the windows.  None of the other controls work.  What should I look for and what could possibly be the problem?
CherokeeRam95
Platinum - Posts: 13,725
Posted: July 01, 2013 at 3:01 PM / IP Logged
The window that does work, will it work from both the driver's door and the door it is on?
cherokeeram
Posted: July 01, 2013 at 3:37 PM / IP Logged
Yes, it does
CherokeeRam95
Posted: July 01, 2013 at 4:05 PM / IP Logged
It is either the motor or the switch mounted on the door. You can remove the working switch and replace one of the ones that do not work and see if that fixes that door.
cherokeeram
Posted: July 02, 2013 at 7:03 AM / IP Logged
So, what you're saying is that three out of four motors hav quit working at the same time?
CherokeeRam95
Posted: July 02, 2013 at 7:30 AM / IP Logged
More likely to be internal switch corrosion and/or wire breaks than the motors themselves.
Test the switch outputs from the driver's door, then at the passenger doors, in and out.
Thursday, January 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
