94 Mazda 626 wiring diagram?
jagger
Posted: June 25, 2002 at 8:25 PM / IP Logged
I'd like to install an alarm with ingition disable, does anyone have a wiring diagram for a 94 Mazda 626 LX-V6?
Also, I was wondering if anyone has any experience with connecting the alarm to this car's power door lock system.  Right now, to unlock all the doors, the driver door lock needs to be manually raised from inside or with the key from outside.
Platinum - Posts: 12,488
Posted: June 25, 2002 at 11:23 PM / IP Logged
Mazda
626
1993-1994
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW
IGNITION SWITCH HARNESS
Ignition  #1:
BLACK/ WHITE
Ignition #2:
BLACK/ RED
Ignition  #3:
N/A
Accessory:
BLUE
Brake  Light:
WHITE/ GREEN (+)
SWITCH ON BRACKET ABOVE BRAKE PEDAL
Tach  Signal:
YELLOW
DISTRIBUTOR OR DATA LINK CONNECTOR
Parking Lights:
ORANGE
(+) AT RELAY OR FUSE/JUNCTION BOX
Headlights:
RED / BLACK (LO)
RED / WHITE (HI) AT HEADLIGHT SWITCH(+)
OEM Alarm  Disarm:
YELLOW/RED (-)
DRIVER KICK PANEL OR IN DRIVER'S DOOR
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * Data Link Connector Located On Side Of Fuse/Relay Block On Driver Front Inner Fender Panel Behind Battery.
Mazda
626
1993-1994
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
BLACK/ BLUE
Starter  Kill:
YELLOW
Ignition  +12 Volts:
BLACK/ WHITE
Dome  Lights/Superv:
RED / WHITE (-) ANY PIN
SWITCH OR FUSE/JUNCTION BLOCK
OEM Horn:
GREEN/ ORANGE (-)
STEERING COLUMN HARNESS OR AT RELAY
Power  Lock:
ADD ACTUATOR
IN DRIVER'S DOOR **
Power  Unlock:
ADD ACTUATOR
IN DRIVER'S DOOR **
Trunk  Release:
N/A
Alarm  Input Wire:
Notes:
** - Add Actuator Door Lock
You need to add an actuator for the door lock system to operate via remote control . Look here for starter disable: https://www.the12volt.com/info/diagrams.asp#si
