6.5 L diesel - hard starting/cranking
safetyforce
Member - Posts: 8
Posted: August 17, 2003 at 8:32 PM / IP Logged
 We are working on a 1995 chevy pick up truck with a 6.5 litre diesel engine. The owner states that it is getting harder to start and the crank cycle is getting longer. When the starter engages, it seems as though the batteries are weak.  We checked the batteries which were ok, changed the glow plugs, fuel filter, and air cleaner.  This seemed to help a little. Is there any other electronic parts that may be causing this condition.
safety force vehicle products
Maxst
Silver - Posts: 866
Posted: August 17, 2003 at 11:16 PM / IP Logged
im too familer with diesels...but you check the senors? im sure theres a computer...you could get it dia.
I need quality equipment, feel free to donate.
copcarguy
Copper - Posts: 122
Posted: August 20, 2003 at 2:20 PM / IP Logged
Be sure your grounds are good! 90% of this type of problem is caused by poor grounds, bad cables, corroded connections or all three. If the cables look at all questionable replace them as a matter of course, they are far cheaper than computers and such. Have you checked to make sure the lift pump and injector pump are operating sufficiently? Both of these are extremely important in the 6.5L. Good luck!!
R Jackson
Owner/Installer
TRM Emergency Vehicles
Information is advice only and should be confirmed with OEM or quality test equipment.
Boyertown, Pennsylvania
Maxst
Silver - Posts: 866
Posted: August 20, 2003 at 3:13 PM / IP Logged
Oh thats a definate even on gasoline cars...i had to do and clean all my grounds on my car- 79 civic...its pos.
