1985 BMW stereo wiring
ReubenPaul
Member - Posts: 7
Posted: September 23, 2003 at 12:44 AM / IP Logged
I just finished installing a new stereo into my brother's 1985 BMW 635csi. Because I didn't have access to any wiring diagrams or other help, I had to figure it out by myself. Now that I know what all the wires are for, how do I help others with similar cars? The link I found from the wiring database on this website was very incomplete ( 1985 BMW 633 Stereo Information ). I'm assuming other stereo amateurs with similar years and models of BMW would benefit from my time and effort.
Where do I submit the info?
"Newer is seldom better"
Reuben Paul    1985 BMW stereo wiring -- posted image.
Sebastian018
Silver - Posts: 364
Posted: September 24, 2003 at 10:59 AM / IP Logged
The BEst Way to do is Buying a stereo Harness for the car you are going to install. and Using a Multimeter to check the wires....
Hope this Helps
Sebastian018
Silver - Posts: 364
Posted: September 24, 2003 at 11:01 AM / IP Logged
and, If you need some info in any specific car ... Post your topic under Vehiccle Imformation forum
ReubenPaul
Member - Posts: 7
Posted: September 24, 2003 at 12:06 PM / IP Logged
1) I think you misread my post. I already figured out the wiring and I want to know how to submit it for other people to use.
2) A wiring harness would not help in this case because the OEM unit has nothing to unplug from it (except the speaker wires and some others in seperate plugs). I had to cut most of the wires directly from the back of the unit.
Someone please let me know where to submit this info...
CruisinS&S
Copper - Posts: 225
Posted: September 24, 2003 at 5:38 PM / IP Logged
Sebastian018 said - [The BEst Way to do is Buying a stereo Harness for the car you are going to install. and Using a Multimeter to check the wires....]
for a 1985 BMW there is no wire harness available
Cruisin Security And Sounds
ReubenPaul
Member - Posts: 7
Posted: September 24, 2003 at 7:22 PM / IP Logged
Exactly. I had to cut the wires from the back of the unit.
Could someone affiliated with this site please tell me how to submit information to the wiring database?
Thanks.
