How can I fix this circuit? continued
the12volt
Administrator - Posts: 3,957
Posted: April 02, 2002 at 1:43 PM / IP Logged
Continued from: https://www.the12volt.com/installbay/display_topic_threads.asp?ForumID=1&TopicID=178&PagePosition=1
Hi Daren, I think next time I'm gonna ask you for a credit card first How can I fix this circuit? continued -- posted image.....here's a diagram showing everything as before, but with interrupting power to the extended pulse module. One thing you'll need to check is that the extended pulse module does not provide an output as soon as 12V+ is reapplied to it. If this is the case, I'll have to draw up a different work around for you (fingers crossed).
the12volt
eloshdesign
Member - Posts: 15
Posted: April 02, 2002 at 2:07 PM / IP Logged
I'll give this a try.
After my truck is done I promise I won't bother you for a while.
the12volt
Posted: April 02, 2002 at 2:13 PM / IP Logged
Not a bother at all, glad I could help.
the12volt
Wednesday, June 18, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
