12v to 3v
nevek
Member - Posts: 22
Posted: February 15, 2004 at 5:07 PM / IP Logged
does anyoen have a diagram on how to convert 12v to 3v
for led's
uncpaul728
Member - Posts: 13
Posted: February 15, 2004 at 6:04 PM / IP Logged
Wouldnt that call for a resistor?
nevek
Member - Posts: 22
Posted: February 15, 2004 at 8:30 PM / IP Logged
what resistance resistor?
packmouse
Member - Posts: 6
Posted: February 15, 2004 at 11:14 PM / IP Logged
Hi,
 I am yesterday new to the group. I am just learning but I think a 9 ohn resistor might be correct. I have just started learning about LEDs they are cool. If you ran 3 leds in series each one would depending on the LEDs voltage which some are about 3 volts after lighting the 3 leds 3 volts would be left over and you would have 3 LEDs telling you the power was on. They wouldnt use much battery if it a car battery. Hope this helps
John
Don't throw it away! Ill take it.
superchuckles
Copper - Posts: 89
Posted: February 16, 2004 at 11:28 AM / IP Logged
actually - the resistor would only work, if you know the amount of current being drawn at 3 volts first.  the proper way to do what you're wanting, is to get a voltage regulator - and it just so happens they make a standard regulator, fairly common so it's easy enuf to get one, that is 3.3volt positive output.  the LM2937-3.3 or the  UA78M33 should work for your application.
MielGibson
Copper - Posts: 74
Posted: February 16, 2004 at 8:34 PM / IP Logged
packmouse
Member - Posts: 6
Posted: February 16, 2004 at 10:48 PM / IP Logged
http://www.theledlight.com/ledcircuits.html
I didn't see the for leds at the end of your message. This link should clear it all up regardless of how many you want to hook up. Superchuckles is right I learned from his post. I think the 9 ohm would be for a device that uses 1 amp.
John
speakerman
Member - Posts: 26
Posted: February 17, 2004 at 10:05 PM / IP Logged
I did a lot of led's in my car and I use a 249 ohm resistor on them. It was the lowest I had and tel all work great.
markcars
Silver - Posts: 662
Posted: February 24, 2004 at 8:57 PM / IP Logged
you can always put four LEDs in series directly to the 12 volt supply (assuming each of your LEDs takes 3 v). If you have more than 4, then group them by 4's and put each group of 4 in series. Each group having two wires that go directly (or with a switch or whatever you prefer) to the 12v supply.
12 v + ---------------LED-LED-LED-LED-----|
           |----------LED-LED-LED-LED-----|
12 v -ve-----------------------------------
Sorry about the ugly "drawing". I dont have any
diagramming software yet.
packmouse
Member - Posts: 6
Posted: February 24, 2004 at 10:43 PM / IP Logged
Hi,
 You should have a 3v a 6v and a 9v tap between each LED like a voltage divider circuit I think. If I am wrong I dont mind being told so. I am always a student and if someone corrects me and they are right then I learned. And that is good.
Later
