12v down to 9v
balut
Member - Posts: 10
Posted: February 18, 2004 at 6:06 PM / IP Logged
i have a wireless camera i'd like to use on my car and use the 12v from the car to power it up..the onlything is that the camera needs a 9v power supply..my question is how do i go about scaling down a 12v to around 9v power supply..
thanks
terryr
Member - Posts: 25
Posted: February 20, 2004 at 1:37 AM / IP Logged
fbird08
Copper - Posts: 90
Posted: February 23, 2004 at 10:34 AM / IP Logged
Quite simply. Just make a voltage divider. A simple one would be a 3ohm and a 9 ohm resistor. If you hook up the 3ohm reisistor to 12v then the other side of the resistor to the 9ohm reisistor then to ground, the voltage between the 9ohm and 3ohm resistor will always be 9v. Obviously you will want to use larger resistor values so you dont have huge current drain through those resistors, just make sure the resistors can handle the amout of current you require of them and they are in the same ratio of the 3 and 9 ohm resistors. Ex: 300ohm and 900ohm, 30ohm and 90 ohm, 300000ohm and 900000ohm, etc
hope this helps
Money is just paper
Power is fleeting
But your word is everything,
If your word means nothing,
You are nothing...think about it
markcars
Silver - Posts: 662
Posted: February 24, 2004 at 8:46 PM / IP Logged
If you don't want to be bothered with making it, you can also pick up an adapter from Radio Shack for about $10 to $15 that will plug into the cigarette lighter and have an output cable and a switch for a range between 1.5 volt to 12 volts. They work pretty good. I used one of these to power my laptop. Its been running for me for the last 9 months without a problem.
Mad Scientists
Silver - Posts: 380
Posted: February 29, 2004 at 4:21 PM / IP Logged
[QUOTE=fbird08]
"Quite simply. Just make a voltage divider. A simple one would be a 3ohm and a 9 ohm resistor. If you hook up the 3ohm reisistor to 12v then the other side of the resistor to the 9ohm reisistor then to ground, the voltage between the 9ohm and 3ohm resistor will always be 9v. "
 Until you try to pull some power from that junction point.. any draw at that point will increase the current through the 3 ohm resistor and decrease the 9v that you desire. Using your example of a 3 ohm and 9 ohm resistor voltage divider, and considering a current draw of 500mA, what would be your voltage?
 The math.. 1.5 amps through a 3 ohm resistor would calculate to a 4.5 volt drop. So, instead of your 9 volt, you've got 7.5v.
 Also keep in mind what happens to your voltage divider once the input voltage goes up as the alternator starts charging..
"Obviously you will want to use larger resistor values so you dont have huge current drain through those resistors, just make sure the resistors can handle the amout of current you require of them and they are in the same ratio of the 3 and 9 ohm resistors. Ex: 300ohm and 900ohm, 30ohm and 90 ohm, 300000ohm and 900000ohm, etc"
 Good that you considered the power rating of the resistors, but increasing their resistance will make the voltage drop even worse.. using a 300 ohm/900 ohm resistor voltage divider circuit means that..
 more math.. with no load, the voltage divider is flowing 12v/1200 ohm = 0.01 amps, or 10 mA. Attempting to draw 500mA from the junction point (between the two resistors) would result in a voltage drop of 300 ohm * 0.510 amps = 153 volts.
 Voltage divider circuits have their uses, but this isn't one of them. Best bet is to use a RS DC adapter, or build something using a voltage regulator.
 Regards,
 Jim
xetmes
Silver - Posts: 586
Posted: February 29, 2004 at 7:45 PM / IP Logged
Well I would not go as far as to say a voltage divider is out of the question. Simple problem is no one has given a current requirement. Knowing the current draw will allow you to find best and worst case and find the tradeoff between power wasted and voltage regulation.
Mad Scientists
Silver - Posts: 380
Posted: March 01, 2004 at 6:05 AM / IP Logged
 Well, when you consider that a 9v regulator costs about a buck
http://www.partsexpress.com/pe/showdetl.cfm?DID=7&Product_ID=11444
and can provide up to 2 amps when properly heatsinked... well, what other choice is there?.. <grin>
 True, a current requirement hasn't been provided.. and if the current requirement doesn't vary, and if the input voltage didn't vary so much, and if the current requirements were fairly low (<0.1 amp), then just maybe a voltage divider would be acceptable.. they work well as a voltage reference, but not very well as a power source. Just the cost of a 9 ohm resistor in the watt size required would be more than the cost of a regulator.
 Can we get a current requirement from the OP?
 Regards,
 Jim
markcars
Silver - Posts: 662
Posted: March 01, 2004 at 9:22 AM / IP Logged
Jim, I agree 100 percent with what you said. If the cost of a regulator is about a buck, no point in spending more money and time and energy to achieve a lesser result if not unpurposeful, although the process might be a bit of fun and learning experience to those who want to learn.
You should have been "Real Scientist" instead of "Mad Scientists".. Just a thought.
Admin/mods: can we please have a new emoticon that says thumbs up? Maybe I'm saying this in the wrong forum.
Mark
xetmes
Silver - Posts: 586
Posted: March 01, 2004 at 9:54 AM / IP Logged
I didnt say a voltage regulatior is not a better idea, but to say a voltage divider unusable is conjecture. Why not use a zener and a resistor? Depending on current requirements power loss may be less. Why not a switching regulator? Linear is watefull.
Mad Scientists
Silver - Posts: 380
Posted: March 01, 2004 at 8:18 PM / IP Logged
 A zener and resistor would be a great improvement over a voltage divider circuit..  Here's what National says..
"The LM78LXX series of three terminal positive regulators is available with several fixed output voltages making them useful in a wide range of applications. When used as a zener diode/resistor combination replacement, the LM78LXX usually results in an effective output impedance improvement of two orders of magnitude, and lower quiescent current."
 As I said a few posts above, the main problem with the voltage divider circuit in an automotive application is that the input voltage varies so much.. if it wasn't for that then, as I said, just maybe a voltage divider circuit would be acceptable.
 More than anything I was amused by the person who originally stated that
"Obviously you will want to use larger resistor values so you dont have huge current drain through those resistors, just make sure the resistors can handle the amout of current you require of them and they are in the same ratio of the 3 and 9 ohm resistors"
 Now understand, the larger you make the resistor value, the more voltage variation you'll see when you try to draw power from the junction. I did the math in an above post.
 A couple years ago I needed an alternate power supply for a digital camcorder.. I was taping a wedding and needed hours of battery power. So I used an adjustable voltage regulator and a number of 12v 7ah SLA batteries. It worked extremely well with varying current draws from as little as 300mA to over 1 amp. I'll admit that I was a little apprehensive the first time I connected the camcorder (I had bought it a year earlier for $800) but things worked out well. I did some power measurements (power in vs power out) and don't remember any horrible no-load current draws.. any way you look at it, the voltage regulator method will be more efficient than a voltage divider circuit.
 My intention was to point out the downsides to using a voltage divider circuit for this application.. the person who initially presented the idea didn't seem to understand the principles involved..
 On to other things.. Mad Scientists Club
http://www.madscientistsclub.com/
 I read them when I was just a kid.. they were recently reprinted by purple house press..  great stories about really smart kids.
 few months ago the HVAC system in the house stopped working.. I came home Saturday afternoon to a hot house. Not good. With all the cr*p I bring home (as my wife puts it) I knew that if I could get the AC working again using stuff I had 'in-stock' then life would be good in the future with regard to electronics stuff being brought home. I ended up using a variac to generate the 24VAC and ran it through a Valhalla Scientific Wattmeter to monitor the voltage and watts. Now the Wattmeter sells used on the Internet for about $900 and the variac probably goes for a couple hundred. So I've got around $1000 in gear replacing a $10 furnace transformer.. but it worked.
 I've got a pretty good workbench setup.. I can generate up to 300Vdc @ 7 amps, and on the AC side I can get about 280Vac. Lots of meters and other test equipment. Just stuff I've collected over the years.
 Regards,
 Jim
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
