Trunk Release
asab16
Member - Posts: 44
Posted: February 24, 2004 at 11:16 PM / IP Logged
Guys 95 Lesabre as  usual. Need some help. The Trunk release switch is hard to get @ any advice.(For RS. with trunk release.)
 I can touch the wires behind the switch  but its difficult to Tap since its so HIGH. So I attempted to get the wire @ the Glove BOX...there is a switch there 4 trunk release ON and OFF. Both these black wires are 12volts constant/ when I checked with my meter. I see two black wires behind the trunk release switch and 1 orange with black stripe wire and a Grey wire. I suppose the ORANGE / black and Grey is for the lumination of the trunk release switch. Anyway could somone tell me any other place where I can tap the wires for trunk release. If I have to do @ the switch will either of the 2 black wires work? and whats the relay setup.
THANKS
Oh and p.s <----please answer this one......I have keyless entery and trunk release on the buick........taping the wires for R.S-keyless wont hurt I hope?Trunk Release -- posted image.
BByinstaller
Member - Posts: 10
Posted: February 24, 2004 at 11:21 PM / IP Logged
you can normally get the trunk, brake, parking light, and door trigger all in the driver side door runner on most older cars. i would try there
BByinstaller
Member - Posts: 10
Posted: February 24, 2004 at 11:23 PM / IP Logged
my info says that its a + BLACK/ white wire in the drivers kick. so try there and the door runner
asab16
Member - Posts: 44
 Thanks u probably right.....there are actually 3 black wires in the door runner.....I wanna play safe. I want to keep the wiring stripping to a mInium.......ummm could u tell me another thing.....the relay setup on this
asab16
Member - Posts: 44
Posted: February 24, 2004 at 11:29 PM / IP Logged
thanx 4 the reply.........Black with white stripe ??? In the drivers RUnner...???
BByinstaller
Member - Posts: 10
Posted: February 25, 2004 at 12:34 AM / IP Logged
well im not sure what system you are putting in so im not sure what your trigger is but ill show you as if its a neg output from the RS
term 85 goes to neg out from RS
term 86 and 87 goes to constant +12
term 30 goes to the trunk pop
thats it
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
