Direct wire, astro chart
Hymer
Silver - Posts: 695
Posted: December 20, 2004 at 10:06 PM / IP Logged
Anyone know how to cut and paste off either one of these?
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
auex
Platinum - Posts: 5,041
Posted: December 20, 2004 at 10:19 PM / IP Logged
Nope, I don't bother. You can hit the print page, view, toolbars, and address bar. Then copy the link and do what you will with it.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
KarTuneMan
Platinum - Posts: 7,056
Posted: December 21, 2004 at 3:05 AM / IP Logged
I have "copyed" and "pasted"  several pages from the directechs page.......
U can only cut 1/2 page at a time ( if your lucky)
I left click and drag to half the page.....then right click select copy
Go To post reply on the 12 volt page............click "paste"  then post reply
Be patient....it takes a while  (on dial up anyways)
KarTuneMan
Posted: December 21, 2004 at 3:09 AM / IP Logged
As far as the astrochart goes..........good luck!
I am an astroflex dealer and I can not get info from the astrochart AT ALL to post on the12volt.com
It's "as they say"   proprietary....I believe thats the term
You can try the "print screen" tab on your keyboard. You have to save it before you can send it though?????
