acc power always on
whoamioitsme
Member - Posts: 25
Posted: January 13, 2005 at 4:30 PM / IP Logged
Hi all I am new hear n it looks like a good place
But on to my ? I have a dodge ram 1500 quad n the other night when i shut it down the raido wouldn't go off pulled the fuse for the night .lol. Looked into it a bit the next day an have found that the int lights don't work when i use my factory door remote like they use to n it seems that lots of acc power things do with the keys off now like cig lighter mirrors .Any help would be appriatedget me a head start I have a prety good under standing of wiring so should b able to fix it but lookin for a good head start from more knowlegable people
Thanks in advance  Dan
godd dan it
Copper - Posts: 447
Posted: January 13, 2005 at 8:54 PM / IP Logged
Check your fuses.
Hymer
Silver - Posts: 695
Posted: January 13, 2005 at 9:22 PM / IP Logged
Sounds like a relay is stuck.. power everything up then shut down and tap every relay you can find.. listen for a buzz or a click.. It could be a bad ign switch too.... with the key out you should have no power to the accy wires in the harness...
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
whoamioitsme
Member - Posts: 25
Posted: January 15, 2005 at 10:43 AM / IP Logged
Thanks all for the replys
All fuses r good pulled every relay  an fuse no change yet will keep n update going any other leads all
mjvandermuss
Member - Posts: 22
Posted: January 17, 2005 at 7:58 AM / IP Logged
what year is your truck?  many of the new vehicles have the stereo wired so it stays on until the drivers side door is opened.  do not know about the acc problem but this may be the stereo problem.
Cpl Moose
USMC Iraq
whoamioitsme
Member - Posts: 25
Posted: January 17, 2005 at 12:06 PM / IP Logged
thanks but it is a 99 and i think that opt didn't come in till 03 but thanks just the same
I am leaning towards the CTM (central timer mod ) or also called the body mod
have seen somany elect probs with theys dodges after lookin thru the net leads me to belive that dodge had a poor grounding practice for this truck and things just burn out as well as using just high enough grace of wire any changes just burn em up
whoamioitsme
Member - Posts: 25
have seen somany elect probs with theys dodges after lookin thru the net leads me to belive that dodge had a poor grounding practice for this truck and things just burn out as well as using just high enough grade of wire any changes just burn em up
whoamioitsme
Member - Posts: 25
Posted: January 17, 2005 at 12:09 PM / IP Logged
opps
Monday, November 3, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
