95 isuzu rodeo wiring diagram and ?
ryano
Posted: March 09, 2005 at 9:01 PM / IP Logged
The left turn signal on my rodeo is out.  It started by the indicator on the dash blinking fast and the relay clicking fast, then the indicator light went out, but the relay is still clicking fast.  So far I have tried to replace all turn signal bulbs on both sides, and the flasher relay.  I took a test light and Im getting a signal under the dash where the jack is coming from the steering column.  The fuse is also good.  I looked at the wiring by back and front bulb, but dont see a loose wire, or anything touching ground.  I followed it back until it went into a big bundle with all other wires.  Any info would be appreciated.  Also a wiring diagram would help a lot.  Thanks in advance.
Ryan
Chad7n7
Silver - Posts: 408
Posted: March 10, 2005 at 9:58 PM / IP Logged
Kind of a shot in the dark, but is there a possibility that you were getting moisture inside the lenses?? I had that problem before, I was getting moisture in the lens, which in turn caused the plugs to corrode on the bulb contacts. Scraped them off good, and it solved my problem.
ryano
Posted: March 11, 2005 at 6:39 AM / IP Logged
I already tried to scrape the contacts.  They were pretty corroded, but it didnt do any good.  Im wondering if there is any other spots along the wiring where corrosion might be occuring.
