91 toyota corolla
jackie
Posted: December 08, 2002 at 1:01 PM / IP Logged
hi all
        looking for wiring diam to hook remote start on standard car 91 toyota corolla
        thanks
        jackie
val richard
Platinum - Posts: 12,488
Posted: December 08, 2002 at 5:13 PM / IP Logged
|              12V|white or BLACK/ red  |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|  SECOND IGNITION|BLACK/ orange        |+  |ignition harness            |
|        ACCESSORY|blue/red            |+  |ignition harness            |
|       POWER LOCK|blue/white          |-  |driver's kick panel         |
|     POWER UNLOCK|blue / YELLOW         |-  |driver's kick panel         |
| PARKING LIGHTS +|dk. green           |   |driver's kick panel         |
| PARKING LIGHTS -|lt.grn or lt.grn/blk|   |steering column             |
|       HEADLIGHTS|RED / white *2        |-  |steering column             |
|     DOOR TRIGGER|blk/wht or blk *1   |-  |2 pin plug at fusebox       |
|  TRUNK/HATCH PIN|RED / white *3        |-  |light or sw. in trunk       |
|         HOOD PIN|red                 |-  |anti-theft mod. or pin      |
|  FCTRY ALARM ARM|white or blue / YELLOW|-  |dr. kick or theft mod.      |
|FCTRY ALRM DISARM|wht/grn or blue/wht |-  |same                        |
|       TACHOMETER|black               |   |igniter or fusebox          |
|       BRAKE WIRE|GREEN / WHITE         |+  |brake pedal switch          |
|     HORN TRIGGER|GREEN/ red           |-  |steering column             |
|           WIPERS|blue/black          |+  |steering column             |
|  LF WINDOW UP/DN|grn or rd,yel or grn|A  |driver's door switch        |
|  RF WINDOW UP/DN|GREEN/ red, blue/wht |A  |dr. door or kick panel      |
|  LR WINDOW UP/DN|RED / grn, blue/black |A  |dr. door or kick panel      |
|  RR WINDOW UP/DN|RED / black, yellow   |A  |dr. door or kick panel      |
Notes:
*1 Anti-theft module, 18 pin plug, pass. kick panel  *2 Also ground RED / green for cars with retractable headlights.  *3 Wagons tailgate common with doors. Also at anti-theft module at pass. kick panel.
Wednesday, February 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
