2003 Dodge Caravan Accessory Wire
arausch
Posted: December 26, 2002 at 2:37 PM / IP Logged
Hi,
I own a 2003 Dodge Caravan, and I'm trying to hook up a cd-changer.  Unfortunately I've been unable to find a switched accessory wire to hook it to.  I understand from other posts that it should be a PURPLE / orange wire, but the only PURPLE / orange wire I can find is hooked to the door chime (door is open buzzer).
Can someone provide me with a location for a wire to hook this to?
Thanks,
Andrew Rausch
Platinum - Posts: 12,488
Posted: December 26, 2002 at 4:42 PM / IP Logged
IGNITION-----------------pink/white--------------| +  |-------------ignition harness .
arausch
Posted: December 30, 2002 at 9:57 PM / IP Logged
Installed and working great.  Once again, thanks Jeff.
You are definitely a valuable asset to the12volt.com
Andrew Rausch
Posted: December 30, 2002 at 10:41 PM / IP Logged
No problemo 2003 Dodge Caravan Accessory Wire -- posted image.
