Wiring Diagram for 02 suzuki XL-7
dIGILIN
Posted: December 31, 2002 at 10:57 AM / IP Logged
Need lock and tach info.
Thanks, Rick.
Platinum - Posts: 12,488
Posted: December 31, 2002 at 5:13 PM / IP Logged
|              12V|WHITE/ green         |+  |ignition harness            |
|          STARTER|BLACK/ red           |+  |ignition harness            |
|         IGNITION|BLACK/ blue          |+  |ignition harness            |
|  SECOND IGNITION|blue/black          |+  |ignition harness            |
|        ACCESSORY|yellow/black        |+  |ignition harness            |
| SECOND ACCESSORY|blue *1             |+  |ignition harness            |
|       POWER LOCK|pink                |-  |keyless entry module *2     |
|     POWER UNLOCK|pink/green *3       |-  |keyless entry module *2     |
|       LOCK MOTOR|blue                |   |keyless entry module *2     |
|     UNLOCK MOTOR|blue/white          |   |keyless entry module *2     |
|    DISARM DEFEAT|blue/red            |   |keyless entry module *2     |
| PARKING LIGHTS +|RED / yellow          |   |driver kick panel           |
| PARKING LIGHTS -|RED / blue            |   |headlight sw or keyless * 2 |
|       HEADLIGHTS|gray/black          |-  |headlight switch            |
|     DOOR TRIGGER|BLACK/ red           |-  |keyless entry module *2     |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|tied in with doors  |   |                            |
|       TACHOMETER|brown               |   |instrument cluster or PCM *4|
|      SPEED SENSE|blue / YELLOW         |   |instrument cluster or PCM *4|
|       BRAKE WIRE|GREEN / WHITE         |+  |brake pedal switch          |
|     HORN TRIGGER|blue/green          |-  |steering column or keyless*2|
|           WIPERS|blue(L), blue/red(H)|+  |steering column             |
|  LF WINDOW UP/DN|yellow - red        |A  |driver window switch        |
|  RF WINDOW UP/DN|grn/blk - RED / blk   |A  |driver door harness         |
|  LR WINDOW UP/DN|grn/yel - RED / yel   |A  |driver door harness         |
|  RR WINDOW UP/DN|grn/wht - RED / wht   |A  |driver door harness         |
| SUN RF OPN/CLOSE|yellow - green      |   |sun roof motor              |
|        RADIO 12V|RED / green           |+  |radio                       |
|     RADIO GROUND|black               |-  |radio                       |
|     RADIO SWITCH|WHITE/ black         |+  |radio                       |
| RADIO ILLUMINATE|RED / yellow          |+  |radio                       |
|    POWER ANTENNA|                    |   |                            |
|       LF SPEAKER|                    |   |                            |
|       RF SPEAKER|                    |   |                            |
|       LR SPEAKER|                    |   |                            |
|       RR SPEAKER|                    |   |                            |
Notes:
*1 Not required for remote start.  *2 The door lock & keyless entry module is located above the driver kick panel.  *3 Unlock requires a double pulse.  *4 The PCM (Powertrain Control Module) is behind the glove box.
dIGILIN
Posted: January 01, 2003 at 4:43 PM / IP Logged
Thanks Jeff.
Posted: January 02, 2003 at 8:16 AM / IP Logged
No problemo
