python 881xp alarm
tnez2
Member - Posts: 26
Posted: March 19, 2006 at 12:39 PM / IP Logged
Hi guys new to form. I have a python 881xp on my 2005 mustang, I needed to know how tp program the passive arm on this unit. the book does not say much on it ,and i called the dealer who installed it but the techs went home, and he said that he thinks that they have to set the passive arming.
mobilecustoms
Silver - Posts: 397
Posted: March 19, 2006 at 1:48 PM / IP Logged
go to the download section of this site and look for the dei viper 791xv install guide. it will tell you in there. they are the same system.
tnez2
Member - Posts: 26
Posted: March 19, 2006 at 3:03 PM / IP Logged
Thanks  mobilecustoms that did the trick.
tnez2
Member - Posts: 26
Posted: March 19, 2006 at 3:11 PM / IP Logged
Hey mobilecustoms Ihave one more questin sorry, when it self armed  how come it does not show that it is arm and locked on the remote transmiter. or is there a way to do that to. thanks
mobilecustoms
Silver - Posts: 397
Posted: March 19, 2006 at 4:33 PM / IP Logged
look in the owners manual about the programming button on the back of the remote. Press it and hold until it beeps. then press and release star and wait for it to beep again. Then try and see if that works. IT is the command page mode or something like that make sure it is on.. Do you see the rx in the remote display flashing like every 5 seconds?
tnez2
Member - Posts: 26
Posted: March 19, 2006 at 4:58 PM / IP Logged
mobilecustoms thanks that worked great, you sure know your stuff. we need more people like you out there
mobilecustoms
Silver - Posts: 397
Posted: March 19, 2006 at 5:22 PM / IP Logged
thanks- did that work?
tnez2
Member - Posts: 26
Posted: March 19, 2006 at 8:49 PM / IP Logged
yes it worked but now the auto start wont work. i dont know if i did somthing wile i programed it . it wont start unless the key is in or right next to it for some reason the bypass module is not reading the chip now so it wont start.
mobilecustoms
Silver - Posts: 397
Posted: March 20, 2006 at 6:34 AM / IP Logged
what does the car exactly do? any theft light blinking? What bypass did you use?
tnez2
Member - Posts: 26
Posted: March 20, 2006 at 7:57 PM / IP Logged
mobilecustoms sorry i did not get back to you but i found out what the problem was. the key in the bypass module was erased by the dealer when thay programed the spare key. all is working now thanks for all your help.
