Breaking glass with a chip of porcelain
Hymer
Silver - Posts: 695
Posted: October 09, 2006 at 3:45 PM / IP Logged
I happen to run accross this somewhere on the net.. Just thought it was BS .. well it actually works! Someone said a chip of porcilan off of a spark plug will shatter a wondow without makking a sound... Yeah right... We had junk car , and lookiie there a spark plug.. A few smacks with the bfh, and we had chips of porcilain... threw one the diameter of a pea, yet very thin... and a busted window.. no sound oof anything... me and my bud just looked at each other in amazment....   I suppose it could be a goood anti-tailgateing device???? weird though...
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
Moderator - Posts: 12,488
Posted: October 09, 2006 at 5:38 PM / IP Logged
We did tis about 20 years ago in my buddies junk yard and we were shocked it did it as well. It's because of the tempered glass that the porcelain can spider the whole windshield or side glass. I believe the Life Hammer's were porcelain tipped, for those who remember this product. Just to add that if you have a security system that has glass breakage mic, it will trigger and set off the alarm system.
Flakman
Copper - Posts: 365
Posted: October 10, 2006 at 1:27 PM / IP Logged
Not suprising since porcelain has a Moh hardness rating of about 5-6 which is harder than most steel. I always liked using an automatic center punch to shatter windshields myself Breaking glass with a chip of porcelain -- posted image..
The Flakman
I feel strange. I have deja vu and amnesia at the same time.
John | Manteca, CA
bigscrun
Member - Posts: 6
Posted: October 13, 2006 at 6:02 PM / IP Logged
If you sell the AutoPage infrasonic sensor it will trigger with the spidering of the glass.
hex0rz
Copper - Posts: 94
Posted: October 15, 2006 at 10:06 PM / IP Logged
In street terms its called shatter rock around here. Many thiefs use it to break windows silently. It does'nt work well since it triggers the sensor for the alarm if you have a window mic. Although, I hear you run a good chance of preventing it if you put duct tape on the window. Supposedly it will keep it from shattering. Leaving a spidered window, pry it out with a screwdriver and pop, its out.
You once again won't get far because you have to defeat the other sensors.
Vehicle: Mazda B2200 1989 X-Cab
Audio System:
1. (2) MTX TA3401
2. (2) MTX Thunder 7500
3. (1) MTX TA3202
4. Eclipse Fujitsuten SC8264 Component series
5. Pioneer Premier DEH-P770MP
5150azn
Silver - Posts: 584
Posted: October 16, 2006 at 10:31 AM / IP Logged
Porcelain + Sling shot = Revenge
Tell the Snap-On guy I'm not here!
audiophyle_247
Copper - Posts: 79
Posted: October 28, 2006 at 12:52 AM / IP Logged
Window tint works against you there too :(  (replaces the need for duct tape)
Worked on my car 2 years ago, alarm never sounded at all & they just pulled the pass window out after breaking it.
Unless it raises the hair on the back of your neck, its only noise!
master5
Silver - Posts: 1,123
Posted: October 29, 2006 at 12:49 AM / IP Logged
Actually had this happen to me a few years back,
I woke up, went to my truck and thought I left the window down. When I opened the door I saw the glass all over. The first thing I did was check my led diagnostic and realized my alarm had never gone off. They apparently broke the glass without triggering the shock sensor (which I had set sensitive). Must have crawled in after they broke it. Good news is the only thing they took was some CD's..you know the ones from columbia house that's like 12 for a penny. So no big financial loss other then a window.
What I did to prevent this was install an RF field disturbance detector. I figure nothing will stop them from breaking a window if they desire but I at least want my alarm to sound. It is very diffcult to enter the vehicle with that kind of sensor without sounding the alarm. Have had no problems since. I now do a few other "tricks" as well but for contents nothing beats a prox, IMO.
pmh61
Copper - Posts: 151
Posted: November 13, 2006 at 2:00 AM / IP Logged
Yea when i was in high school some dumb fool discovered this. They started to tell me about it and how he was gona break into peoples cars that weekend and take sh#$. And go f-ing figure those dumba##es break my moms window and take a few cd's (not knowing i live there). So i took a sledge hammer and visited there house there parents rather new car needed new windows all around and so did the front two windows of there house. And all be damned if it didn't snow the next day Breaking glass with a chip of porcelain -- posted image. Breaking glass with a chip of porcelain -- posted image. Breaking glass with a chip of porcelain -- posted image.
Thursday, August 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
