02 silverado weird problem
sprawl85
Copper - Posts: 204
Posted: October 26, 2006 at 10:50 PM / IP Logged
Ok, so I'll just be driving down the road, and the dome light will flicker on then off and there will be a click coming from the drivers side lower dash. Sounds like a relay clicking...
02 silverado crew cab 5.7l
Any ideas? Could it be the factory security thing going bad? It isn't really even an alarm, just kinda like a dome light sensor that honks the horn right? That is why I would think that. Also, just for future reference, where is this factory alarm box located at, I looked up under the driver side and under the kickpanel plastic and couldn't see it, but it's dark out.
Someone help, this is gettin really annoying.
fiberglass reminds me of peanut brittle... but fiberglass tastes better!
doibuy
Copper - Posts: 177
Posted: October 27, 2006 at 12:05 PM / IP Logged
It isn't an alarm, only keyless entry.  Sounds like it could be a bad door pin switch.  The pin switches are in the door latch.  When the dome light comes on does it show that a door is open?
master5
Silver - Posts: 1,123
Posted: October 27, 2006 at 5:02 PM / IP Logged
Or, if its an aftermarket keyless module perhaps the domelight supervision relay/wiring is messed up. But most liklely a bad/loose pinswitch as stated above.
Keep us posted
sprawl85
Copper - Posts: 204
Posted: October 27, 2006 at 11:32 PM / IP Logged
Just standard keyless entry that came with the vehicle, and no door ajar light on the dash, door pin is what I thought at first, but that doesn't make the relay click right?
master5
Posted: October 28, 2006 at 12:12 AM / IP Logged
Generally no. You do have a weird problem if this is a factory unit. Are you 100% sure it is factory and not "dealer installed"? There is a difference.
If the unit is factory installed I would need a factory Service manual to help you, but I don't have one.
Now another approach..... most likely this is a problem with the domelight module, may not neccesarly be the keyless module. Try to locate what is clicking and check the connections. Also ,for giggles make sure no fuses are loose (seen this happen from people jamming wires into them).
If all else fails find another module at the junkyard...cross your fingers and plug it in.
Keep us posted.
master5
Posted: October 28, 2006 at 12:17 AM / IP Logged
Also check the harness behind the headlight switch..could be shorting causing the module to click. I believe on that year truck the wires go to the domelight module.
sprawl85
Copper - Posts: 204
Posted: October 28, 2006 at 12:29 PM / IP Logged
Yessa master (hehe, had to throw that in). No, but I wanted to let you know I am going to check all that stuff today, so tonight I should be able to fill you guys in on if it was one of those or not.
master5
Posted: October 28, 2006 at 12:34 PM / IP Logged
cool beans, and no master jokes unless you are bringing me some lemonade..lol
sprawl85
Copper - Posts: 204
Posted: November 01, 2006 at 12:14 PM / IP Logged
ahaha, you know, I reseated the relay that was clicking when it would happen and it hasn't happened since then. It happened so randomly though, it may not be fixed, but I think it is.
master5
Posted: November 01, 2006 at 8:05 PM / IP Logged
yep, sounds like a loose or corroded connection at that relay.
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
