2005 dakota cruise control
uwDawson
Member - Posts: 7
Posted: December 29, 2004 at 4:36 PM / IP Logged
I' m having trouble with the installation of a cruise on an 05 dakota.  Any helpful suggestions would be appreciated.
uwDawson
Member - Posts: 7
Posted: December 29, 2004 at 5:33 PM / IP Logged
I'm having trouble identifying the speed sensor wire.  Right now everything seems to be working but it just keeps accelerating, it wont stay at a constant speed.
mo12v
Posted: December 30, 2004 at 10:06 PM / IP Logged
Check your Ground wire.  Make sure your throttle cable connection has about 1/8 " slack.  Also I have found shift problems if you tap into wrong wire
MO
Wednesday, December 31, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
