87 winebago with chevy 440
Rt_tt
Member - Posts: 9
Posted: March 01, 2006 at 1:44 PM / IP Logged
I'm trying to install a rostra cruise control in a 87 winebago with a chevy 440 I believe.  I have everything installed and I can't get it to work.  Does anybody have any experience with one of these beasts?
mo12v
Posted: March 01, 2006 at 2:28 PM / IP Logged
Which Rostra Cruise?
MO
ff-mike
Copper - Posts: 199
Posted: March 01, 2006 at 2:40 PM / IP Logged
No 440 in the Chevy lineup, how about a 350 (5.7l) or a 454 (7.5L)
Rt_tt
Member - Posts: 9
Posted: March 01, 2006 at 2:59 PM / IP Logged
it must be the 454 then and it is a global cruise module,  I have a vss reading from a signal generator, and it seems as if it won't activate when i press the set button.
mo12v
Posted: March 01, 2006 at 6:39 PM / IP Logged
If it is the 1223, be sure & check your switch settings.  Your Brake Light Connection ( should show GROUND when Pedal is Up ), and GROUND Wire connection at the Servo
Where do you have the BLUE wire connected?
MO
Rt_tt
Member - Posts: 9
Posted: March 01, 2006 at 8:38 PM / IP Logged
All my dip switches seem to be set right.  I wasn't getting a solid ground on my bake switch so I put in a relay to give it ground when up and 12v when ther brake is pressed and also double checked my main ground and it was good but I moved it to and all my tests seem ok,  It detects the set button, the resume button  and the brake.  It also detects the tach signal properley and the only thing i can't test is my VSS since I don't have a large enough jack to lift up the vehicle, but the signal generator does give me an AC signal when I drive and test it with my test meter.  My blue wire is hooked up to the tach wire.
mo12v
Posted: March 02, 2006 at 9:14 AM / IP Logged
Be sure the RED wire has 12 volts Constant +
BROWN wire has Ignition 12 volts +
Try GROUNDING the Blue Wire.
Check Throttle Slack for no more than 1/8 inch
MO
Rt_tt
Member - Posts: 9
Posted: March 02, 2006 at 10:34 AM / IP Logged
my red has 12v+ constant, my brown has 12v+ ignition, I've tried grounding the blue wire and my slack is good.
mo12v
Posted: March 02, 2006 at 12:29 PM / IP Logged
Not much left except the Pulse Generator & / or Settings.
Pretty simple Install.  What Handle are you using?
MO
Rt_tt
Member - Posts: 9
Posted: March 03, 2006 at 3:13 PM / IP Logged
Thanks for all of your help guys. I got it working now.
