Rookie needing to move & edit a post
smashpdx
Member - Posts: 24
Posted: July 28, 2006 at 2:07 PM / IP Logged
Howdy,
I posted the topic "Fixing e-brake signal" under Car Security and Convenience. After reading through the Relays forum I'm thinking maybe it should go over there, because what I'm trying to do is design a circuit. I'd also like to change to topic to "Fixing e-brake signal with relay or blocked diodes?"
Can one of the mods help?
Thanks!!!
the12volt
Administrator - Posts: 3,957
Posted: July 28, 2006 at 2:34 PM / IP Logged
Done ;)
Rookie needing to move & edit a post -- posted image. the12volt • Support the12volt.com
smashpdx
Member - Posts: 24
Posted: July 28, 2006 at 2:47 PM / IP Logged
Thank you!!
the12volt
Posted: July 28, 2006 at 3:27 PM / IP Logged
You're welcome ;)
