fg box, aluminum substructure
gn4whln
Posted: April 16, 2009 at 4:21 PM / IP Logged
Has anyone here built a fiberglass box using a welded aluminum, stainless, or mild steel substructure? If so, I was wondering if anyone has had any adhesion problems between the glass and metal. I am thinking of building a box like this for my '99 Ram using the aluminum to form the skeleton internally and the mounting externally.
ckeeler
Gold - Posts: 1,461
Posted: April 16, 2009 at 4:24 PM / IP Logged
fiberglass sticks very well to almost any type of metal. just make it extremely rough before hand and clean it well with alcohol.
gn4whln
Posted: April 16, 2009 at 5:35 PM / IP Logged
Thanks! I have always built MDF boxes but I have decided I wanted to build a fiberglass box this time so I was doing some research on the construction techniques and got to thinking I could build a stiff, lightweight, structure out of aluminum. Now, if I can only create time out of thin air to get this thing done, I'll be set.
ckeeler
Gold - Posts: 1,461
Posted: April 16, 2009 at 8:08 PM / IP Logged
man if you can pulloff that let me know how you did it. fg box, aluminum substructure -- posted image.
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
