F/G Spare Tire Well & Heat
seven
Member - Posts: 20
Posted: August 15, 2003 at 11:54 PM / IP Logged
Ok so i have a 03' Tiburon and i just f/g the spare tire well..  i noticed that it gets extremly hot in the tire well and my amps will eventually overheat..
my setup is simple.. i have a peice of MDF that sits ontop of the stock mounting hole for the spare tire.. theres about 1" from the bottom of the S/T/Well to the MDF... then i have 3 layers of f/g and 2 coats of body filler ontop + primer/paint/clearcoat...
now i really need to vent out the heat..
i was thinking like 4-6 small +5v computer fans to circulate the hot air and vent it out through the peice of MDF that sits ontop of the amps..  it has a 8"X10" peice of plexiglass in it..
any suggestions well help...
   - Seven
Moderator - Posts: 12,488
Posted: August 16, 2003 at 8:04 AM / IP Logged
Even 4 fams with two wired in revese will work properly . Look at he fan's cm rating and make sure you get one that is rated high as it will move more air.
JamesRH
Copper - Posts: 102
Posted: August 16, 2003 at 9:15 PM / IP Logged
put a heat shield around your exhaust to stop the heat being produced, and get some 12 volt computer fans so you dont have to worry about voltage differences. I agree that 4 fans is enough, 2 blowing in one side and 2 blowing out the other side.
seven
Member - Posts: 20
Posted: August 17, 2003 at 2:35 AM / IP Logged
thanx
Sunday, July 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
