fiberglass interior?
thepenguin
Posted: December 17, 2003 at 9:20 PM / IP Logged
I want to get my interior painted but i want it to look like the finish of a car paint job and i have heard many different ways of doing it but idon't know what would be the best. I want to fiber glass it but i don't  know exactly what to do.
tcvaldez
Posted: December 18, 2003 at 10:17 AM / IP Logged
You can sand the texture smooth, use some filler primer and then paint it.
Paint it using light coats and then top it off with layers of clear.
Later
TC
audiomechanic
Silver - Posts: 388
Posted: December 18, 2003 at 10:49 AM / IP Logged
you might want to remember to add some flex additive to the base and clear for the pieces that might shift a little either when you are putting them in or while the car is moving..........or else it can crack. also some brands like Dupont chroma clear and base has a little more flex to it. ppg also makes a plastic primer system.
Trevor
Wherm
Copper - Posts: 51
Posted: December 22, 2003 at 12:06 AM / IP Logged
good calls on sanding out the texture and adding flexibilizer.  I think a lot of people are mislead when they see shiny interiors.  Just because it's shiny doesn't mean it's fiberglass.  The best way to give your interior that shiny fiberglass look is to spray the parts with a high build primer, and sand them till they're smooth.  Repeat the process untill you're satisfied, and then paint and clearcoat the parts.
Thursday, September 11, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
