fiberglass door pannels?
lowaccordlow
Posted: February 11, 2004 at 3:01 PM / IP Logged
whats up every one i want fiberglass door pannels and i dont know where to find that and i dont know how to do fiberglass so that is out of the question if you could let me know of companys or people that could hook me up let me know thanks a lot
LowAccordLow
Platinum - Posts: 12,488
Posted: February 11, 2004 at 3:12 PM / IP Logged
Are you looking for the entire door or just speaker pods ?? What year Accord ?? 2 door or 4 door ?
lowaccordlow
Posted: February 11, 2004 at 3:24 PM / IP Logged
the whole door pannel with speaker pods and every thing 2 door
LowAccordLow
kustomcarluvr
Copper - Posts: 73
Posted: February 12, 2004 at 11:56 AM / IP Logged
Where do you live?
Matt
lowaccordlow
Posted: February 12, 2004 at 1:02 PM / IP Logged
i live in FL i eather need some one to do it for me help me out or give me a company name that i can get them from
LowAccordLow
kustomcarluvr
Copper - Posts: 73
Posted: February 12, 2004 at 2:58 PM / IP Logged
Well, I would do it for you but I am in Arizona, I could try to help you and if you read through other postings, other people are already doing it. I will post some pictures of my door panel when I get a chance to take a picture.
Matt
Flaredse
Member - Posts: 7
Posted: February 12, 2004 at 3:42 PM / IP Logged
whats up man. Check out "TEAMPROTOTYPE.COM" they have some sick fiberglass doors. They can make "Anything" for "Anything". Just specify your year make and model. Thye have alot of things like fender flares, kits, light conversions, carbon fiber hoods, splitters, trunks. Lambo kits for the doors. suicide doors too.
hope this helps.
QUincey Morton
Los Angeles
qlm
kustomcarluvr
Copper - Posts: 73
Posted: February 13, 2004 at 9:46 AM / IP Logged
They do have a lot of things, and the door panels look pretty cool, but they all look the same, even for different cars. I have seen like 10 cars in a row at a show with the same door panels, they may have all been friends or from the company or something but still, to have the same door panel is kind of annoying.
Matt
kustomcarluvr
Copper - Posts: 73
Posted: February 13, 2004 at 10:02 AM / IP Logged
With fiberglass you can build anything you want, almost anything looks good when it is done right. Just figure out what you want to make (design wise). Figure out the spots that need to be kept the way that they are because of the door needing to shut. Then build a base from mdf, or using something as a base to form the major shape (build your speaker rings, Deck mounts, anything that will just be sticking out, etc.). Then with fleece, or any stretchy material you can find, tthen make sure that there are little to no wrinkles in the material, then use resin over the whole thing, then you can build up any spots from there, then sand it down, or grind it down, then use body filler to smooth it out.
Matt
annasr02
Posted: February 13, 2004 at 1:54 PM / IP Logged
I know how to double the door panels and all, make a fiberglas "copy" of my door panels, I just don't know to attach it to my stock door panel, without it falling off or anything, suggestions anyone???
Only if I knew the truth...
Monday, January 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
