mixing MEKP and resin, perfect amounts?
soup
Copper - Posts: 79
Posted: February 27, 2004 at 5:04 AM / IP Logged
Ok, I have done a lot of fiberglassing, I still really haven't got the knack for it, I always use it in such small quantities I just mix a whole crap load of MEKP, it hardens withins minutes, I think it is just short of making it buble. I usually fiberglass pieces no larger than 1 foot by 1 foot so it never makes a big difference. I have a few things that I need to fiberglass now that are quite large. Interior panels, dash, and cover for the rear firewall (pontiac fiero)
IF I mix the resin, and it starts to gell, can I mix some acetone in it to thin it and then finish the job?
What is a good trick for mixing the perfect amount of MEKP and resin? I am using polyester btw.
soup
Copper - Posts: 79
Posted: February 27, 2004 at 6:23 AM / IP Logged
Heh, I also just found out that thinning the resin too much with acetone, and then putting it on the felt is not that good of an idea. It barely even soaked into the felt, it just went through it, and then dripped down the inside. I had heard that thinning it would make it soak in better.. how much should it actually be thinned? I had it thinned so it was like milk.
zherm
Posted: February 27, 2004 at 8:46 AM / IP Logged
Hey ,
there's a cool website on fiberglass that has some pretty good pointers for someone starting out working with fiberglass.  there's a lot of stuff there to read, so get a cup of coffee and a nice comfortable chair.
http://www.fibreglast.com
go into "help I'm new" then go into "the learning center" read there online brochures.... this should give you the info you need..
good luck.
Zherm mixing MEKP and resin, perfect amounts? -- posted image.
