Curing Time For Fiberglass
nyguy4u
Copper - Posts: 148
Posted: April 02, 2004 at 9:22 PM / IP Logged
I don't know if this is a stupid question, but here it goes anyway!. After you resin fleece on a subwoofer box, I realize you start glassing after the resin is cured and dry. But when you actually start the layers of glass, can you do one layer after another?. Or after one layer, do you need to wait for it to dry?. If you do need to wait for it to dry, how long usually do you wait in between layers?. And if you don't need to wait.. after building up 6..7..8 layers of chop matt, wouldn't it stay damp with that many layers??.
93accordSE
Copper - Posts: 203
Posted: April 02, 2004 at 9:44 PM / IP Logged
You do one layer after the other. If you wait for layers to dry then you can get air between layers easily. 6-8 layers, you should probably give it a day or two to cure.
hbk00
Copper - Posts: 64
Posted: April 02, 2004 at 10:23 PM / IP Logged
do 1 right after the other you'll use less resin
go custom or go home!!
my12volts
Member - Posts: 36
Posted: April 04, 2004 at 6:15 PM / IP Logged
1 layer after the other better that way........
defective
Silver - Posts: 642
Posted: April 05, 2004 at 9:54 AM / IP Logged
Theoretically...  f/g would take the same time to cure whether it is an inch thick or a mm thick.... it does not need air to dry.... in fact, air causes it to cure slower. Just a little tidbit for ya. Lay it on as thick as you want it or you will just be wasting time and gaining air bubbles.  : )
nyguy4u
Copper - Posts: 148
Posted: April 05, 2004 at 11:04 PM / IP Logged
ok cool.. layering the fleece without waiting will save me ALOT of time.
Another curing question.. the first step, when I resin the fleece.. generally, how long do you wait after you resin the fleece until you start your first layer of glass?.
Thanks for the help so far!
nyguy4u
Copper - Posts: 148
Posted: April 08, 2004 at 10:01 PM / IP Logged
anyone?
dangerranger96
Copper - Posts: 163
Posted: April 09, 2004 at 11:20 AM / IP Logged
let the fleece dry completely before you start to layer on the fiberglass.  This gives you something rigid to lay the fiberglass on and makes it much easier to get the fiberglass going
defective
Silver - Posts: 642
Posted: April 09, 2004 at 2:32 PM / IP Logged
also when you let the fleece dry it is not as heavy and will hold the right curves until dry.  Then you use mat to rienforce the shape
nyguy4u
Copper - Posts: 148
Posted: April 10, 2004 at 9:21 PM / IP Logged
I know all that. I mean actual time wise to wait until I lay the glass. I'm assuming I need to wait for the resined fleece to dry before I lay down fiberglass.. correct?. Question is, how long is the standard wait time from when you finish resining the fleece, to laying down the glass?. hour?.. hours?.. overnight?..
Friday, October 10, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
