flush mounting?
unreal3z
Member - Posts: 21
Posted: April 25, 2004 at 8:00 PM / IP Logged
Ive seen a lot of pics w/ screens and xm radios flush to fiberglass, how is the item secured to the glass and also what is the best stuff to use to get the contour around the item as far as the shaping goes
kickerstang
Copper - Posts: 180
Posted: April 26, 2004 at 11:13 AM / IP Logged
when i do a flush mount tv, i take apart the casing and take out the screen and buttons. then i attach the front casing to whatever i'm flushing it to with speedgrip or cheese strap.  after that i apply a little fiberglass to the back side to give it extra strength. once that is done i apply bondo until i reach the desired shape.  then i sand and paint. put everything back together and then i install and enjoy
what!?!?! you want some??
unreal3z
Member - Posts: 21
Posted: April 26, 2004 at 12:45 PM / IP Logged
what is speedgrip and cheese strap? Also if the unit goes bad or u just want to replace u just cut away the fiberglass on the back?
Thanks a lot for the info
kickerstang
Copper - Posts: 180
Posted: April 26, 2004 at 2:49 PM / IP Logged
cheese strap is also backstrap, it's the stuff that comes with your deck when you get it, it's a piece of metal that is long and skinny with a lot of wholes in it.  speedgrip is an extremely strong adhesive.
and yeah, if you need to replace it you just cut the piece out and basically start all over again
