headliner
toytruck
Member - Posts: 20
Posted: December 06, 2004 at 9:24 PM / IP Logged
I have seen in magazines that some people i assume glass their headliner and paint it.  I have a 91 toyota pickup and the headliner seems to just be vinyl with some snaps on the ends to hold it up i guess. My question is how would i go about glassing it and reattaching it? thanks
auex
Platinum - Posts: 5,041
Posted: December 06, 2004 at 10:14 PM / IP Logged
Well just take it out, strip the vinyl, strip the foam, apply fiberglass(probably about 3 layers of just resin, use mat if cardboard is cracked), sand high spots, apply body filler, sand, sand, sand, prime, then paint.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
toytruck
Member - Posts: 20
Posted: December 06, 2004 at 10:55 PM / IP Logged
im pretty sure my headliner is crappy and is only vinyl with a padding behind, i havent taken it down though to look.  How would i reinstall it, would the plastic button looking clamps still hold it?
ravenndude
Silver - Posts: 250
Posted: December 07, 2004 at 12:02 AM / IP Logged
As long as you aren't putting anying too heavy in the headliner ... such as EQs, LCDs, gauges ... the "plastic button looking clamps" should hold.
auex
Posted: December 07, 2004 at 12:54 AM / IP Logged
Well, if there is no backing then that is a different ball game.
ODLeon
Copper - Posts: 57
Posted: December 08, 2004 at 11:12 PM / IP Logged
its not just held up by the pop rivets. te plastic moulding on the pilars holds it up as well. on mine i just took it out and put fg right on top. but mine was cloth. you need to strip off the vinyl. dont use just resin as it will crack when you put it back in. use 3-4 layers of CLOTH( mat is too thick, and cloth is smoother = less sanding.) so far ive been sanding mine for ~13 hours and i still have ~4-5 to go. i just need to actually take it out of my car again to finish. for some pics, go HERE
toytruck
Member - Posts: 20
Posted: December 09, 2004 at 7:05 PM / IP Logged
thanks for the help guys im not ready just yet to start on it but when i do ill post updates
5150azn
Silver - Posts: 584
Posted: December 10, 2004 at 1:03 AM / IP Logged
Is it me? Or wouldn't it be really really hard to put a fg headliner back in the car without cracking it? I ask because I just put a suede headliner into a H2 and it had to be bent to put in.
Tell the Snap-On guy I'm not here!
realitycheck
Silver - Posts: 751
Posted: December 10, 2004 at 7:41 AM / IP Logged
I think I read on here a long time ago that they were telling a guy that.   That if it has to be bent a lot then it will probably crack, but if you can get it in w/o bending then you'll be fine.   I think thats what I read maybe im confused.
