Fiberglass Material
Walkercustoms
Copper - Posts: 219
Posted: December 24, 2004 at 11:42 AM / IP Logged
Where is the best place to buy fiberglass material online or store?
Captanham
Silver - Posts: 365
Posted: December 24, 2004 at 1:11 PM / IP Logged
the best place i have found is actually uscomposites.com, they have the cheapest stuff and it works pretty good, shipping isn't too bad either, they have carbon fiber and everything too, i think it's actually ment for boats and stuff, but it'll work, also if you go to selectproducts.com they have  A LOT of installation help with everything in the automotive customization area, select will take a wholesale acount, i'm not sure about uscomp. but uscomp is cheaper then select even if your set up as wholesale with select, i've used their FGR on a box and it was just fine, took a little longer to cure then i was used to, i think for fging a box i used the  435 poly resin, they have a lot of choices. hope i helped, EVERYONE HAVE A NICE HOLIDAY SEASON!!
Bad Boys Customs
    audio - video - security
If you use it. Suport it. Donate to the 12 volt!
xtreamcc
Silver - Posts: 467
Posted: December 26, 2004 at 11:55 PM / IP Logged
I goto homedepot. Its $25 a gallon which is the same as it is at UScomposites.
"Shiny chrome when used in conjunction with bikini models is particularly effective in inducing brain deficit disorder"
02 Jeep Grand Cherokee
Monster System on its way.
