glaze putty
redpeppers
Silver - Posts: 483
Posted: December 14, 2005 at 7:04 PM / IP Logged
will glaze putty work good on top of fiberglass to get scratches out?  also do i need to primer the putty before painting?
Where theres is a wire there's a way.
ragoal12
Copper - Posts: 135
Posted: December 14, 2005 at 7:25 PM / IP Logged
glaze putty should work.. but i would recommend using bondo or a skim coat filler... and yes you do need to prime before painting.. otherwise the the final coat of paint will not lay down evenly.. when in question always prime again..
S.O.B custsoms.. South Omaha, Nebraska
jlord16
Silver - Posts: 322
Posted: December 15, 2005 at 6:14 AM / IP Logged
literally prime everything, otherwise it will look odd and the paint job will be crap in the unprimed areas, glaze putty will work but body filler is better suited
Clarion DB36MP
Infinity Kappa Perfect 10"
Respone 800w Mono
ALPINE MRP-F250
*Custom fabrications*
redpeppers
Silver - Posts: 483
Posted: December 16, 2005 at 1:40 AM / IP Logged
will i need to sand the primer before painting?
jlord16
Silver - Posts: 322
Posted: December 16, 2005 at 5:43 AM / IP Logged
i usually do one coat of primer and give it a light sand to make sure there are no inperfections, if i have to sand down some larger lumps i usually do another coat of primer then like a 800 grit sand b4 applying a top coat, i prefer wet and dry snadpaper for 400-2000 grit sanding and i prefer wetsanding
Clarion DB36MP
Respone 800w Mono
ALPINE MRP-F250
redpeppers
Silver - Posts: 483
Posted: December 19, 2005 at 1:06 AM / IP Logged
ok kool thanks.....is there anyway i can reuse my brushes after apply resin ?  That way i dont have to keep throwing every brush away every time i use it.
jlord16
Silver - Posts: 322
Posted: December 19, 2005 at 5:54 AM / IP Logged
yes soak it in acetone for like 10-20mins then take it out and clean the brush with an old rag.  if you leave it in the acetone over night sometimes the acetone evaporates and only gelled up resin is left and then the brush is rooted
Clarion DB36MP
Respone 800w Mono
ALPINE MRP-F250
