where to buy carbonfiber mat
silverdevil
Member - Posts: 11
Posted: January 05, 2006 at 7:40 PM / IP Logged
I need a sheet of carbon fiber mat roughly 6x6 ft. but I don't want to pay an arm and leg for it, I found this:
http://www.cardomain.com/item/FSHCARFMAT
but it's not big enough, I need it big enough to do the floor of my trunk (05 nissan sentra)
2005 Nissan Sentra SE-R Spec-V
Alpine cda-9815, Eclipse Se8365, JL audio 10w0
chrisne77
Member - Posts: 13
Posted: January 06, 2006 at 12:02 PM / IP Logged
http://uscomposites.com/
It's the best and cheapest place I've found.
Be sure and do some trial pieces before attempting the whole trunk floor. From what I've heard and saw CF is very difficult to make look good when finished. It's also very expencive compaired to fiberglass.
jfunk06
Copper - Posts: 64
Posted: January 08, 2006 at 10:55 AM / IP Logged
A trick most guys use, but the thinest CF possible, and do whatever structure building you need to do with FG, then put one final coat of CF when all smoothed and what not.  THis way you use as little CF as possible, therefor saving as much cheddar as possible!
Govenor of Jimcinati
93' GMC Safari XT
silverdevil
Member - Posts: 11
Posted: January 08, 2006 at 1:02 PM / IP Logged
it's not going to be molded at all, it's just going to lay flat on the floor of my trunk
silverdevil
Member - Posts: 11
Posted: January 08, 2006 at 1:03 PM / IP Logged
I found some carbon fiber vinyl, from metra I"m going to try out first
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
