Posted: October 24, 2005 at 6:34 PM / IP Logged
Posted: October 25, 2005 at 5:16 PM / IP Logged
Posted: October 25, 2005 at 5:23 PM / IP Logged
| You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You can vote in polls in this forum |
Tuesday, May 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
This is the relay im talking about
Connect ignition wire to 85, and ground to 86
Then run a heavy enough wire with a 25 amp fuse from the battery to terminal 30 and connect your Ham radio to 87, with appropriate grounding.
Now, when u turn on the ignition the current will flow from battery to terminal 30 to terminal 87, and your radio will have power.
