led power from dimmer switch?
maswindell
Posted: January 28, 2008 at 10:43 PM / IP Logged
I have an 04 Tahoe which has two cubbies in the dash which i want to add a red led in each. I have a lighted traction control switch adjacent to the area of interest. Any reason i can't use that 12 volt supply for my two leds ? I was planning to buy the ones already installed with the resistor, should I wire in series or parallel ?
Thanks for noobie tothis forum and leds
KPierson
Platinum - Posts: 3,527
Posted: January 29, 2008 at 8:09 AM / IP Logged
The LEDs will draw a minimal amount of current so I don't think it would hurt anything.
If the light switch is dimmable, the LEDs may or may not dim in a linear fashion with the other bulbs, but I don't think that would matter.
If both LEDs have current limiting resistors you would want to wire them in parallel.
Kevin Pierson
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
