what kind of switch is this?
bigjohnny
Copper - Posts: 293
Posted: October 26, 2008 at 9:42 PM / IP Logged
This is a switch that was on a circuit board.
I need to replace this with a switch that i can mount in my dashboard.
This switch has 3 positions, this is a drawing of what the switch looks like inside, the red portion is the slide that makes the connections.
Im not sure what type of switch this is or if i can even find something to replace it that ISN'T PCB mounted.
any help would be appreciated.
what kind of switch is this? -- posted image.
Platinum - Posts: 13,725
Posted: October 26, 2008 at 9:50 PM / IP Logged
You will have to remove the switch and use some small ribbon cable to extend the switch to wherever you want to install it.
It is a double pole triple throw switch. It is used for a crossover selector switch, One position for each, full range, high pass and low pass.
bigjohnny
Copper - Posts: 293
Posted: October 26, 2008 at 10:22 PM / IP Logged
its actually from a light flasher.... on/flash/solid.
I just want to make sure i have the right switch, making it remote is no problem.
Here are actual pics of it.
Assembled, position 1, 2 and 3.
Posted: October 27, 2008 at 1:46 AM / IP Logged
If you are needing the switch, you can find one in just about every car amplifier that has a 3 position crossover switch. You can find 2 of them in a 4 channel amplifier.
bigjohnny
Copper - Posts: 293
Posted: October 27, 2008 at 6:30 AM / IP Logged
what i need is more of a toggle/rocker switch, not a slider, though a good quality slider may suffice i dont know.
I dont want to put a tiny little switch on my dash, i have big hands, and need a slighty larger switch :)
Posted: October 27, 2008 at 12:08 PM / IP Logged
The only way I have seen such a configuration is on those slider switches.
KPierson
Platinum - Posts: 3,527
Posted: October 27, 2008 at 1:29 PM / IP Logged
They call those DP3T switches.
They have a few on Digikey.com - here is one that looks promising:( http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=679-1228-ND)
You will just to verify in the datasheet that it switches the exact same way (ie one in per side and three outs per side).
Kevin Pierson
bigjohnny
Copper - Posts: 293
Posted: October 27, 2008 at 5:24 PM / IP Logged
Ive been toying with the idea of a rotary switch also.
I think a rotary switch might work the same way, and a local store by me has one thats configurable in how many connections it has.
Im not sure, maybe i'll use a slider, i really dont like fumbling with them though.
KPierson
Posted: October 27, 2008 at 5:31 PM / IP Logged
Do a search for DP3T on Digikey.com - they have a nice selection of switchs, including rotary, rocker, toggle, slide, etc.
Kevin Pierson
bigjohnny
Copper - Posts: 293
Posted: October 28, 2008 at 7:20 AM / IP Logged
ive been checking digikey, but most of their switches dont have pics, which is something i personally need so i can get an idea of what the switch looks like.
also alot of them dont have links to datasheets etc.
Ive been unable to find a rocker/toggle that functions this way so far, but im damn certain they have to exist.
