led quadra strobe under glove box
rfmcmahon
Posted: August 10, 2009 at 6:02 PM / IP Logged
i have dodge ram 1500 sxt and i just bought some LED quadra strobe lights to put under my glove box but i need a power source, a battery powered source. How do i connect the red and black wired to a power source in the truck?
Ryan
t&t tech
Platinum - Posts: 2,622
Posted: August 11, 2009 at 6:28 PM / IP Logged
Ground the black on a piece of bare metal connnected to the chassis anywhere under the dash, the red leg, you can either test for a twelve volt source under the dash if you have a meter, if not run a piec eof 14gauge wire from the positive battery teminal, fuse it at five amps as close to the battery as possible!
Insert an on/off toggle switch inline on the power wire from the battery so you can toggle the lights on and off
