bmw headlight change to zeon
vincewrd
Posted: August 23, 2009 at 10:26 AM / IP Logged
hi i have a bmw e46 2002 (face lift model) which has normall hedlights i have been offered some zeon hedlights cheap, originall bmw spec will these lights fit straight in or will the wiring be diffrent, many thanks
vward
vincewrd
Posted: August 23, 2009 at 10:39 AM / IP Logged
vincewrd wrote:
hi i have a bmw e46 2002 (face lift model) which has normall hedlights i have been offered some xenon hedlights cheap, originall bmw spec will these lights fit straight in or will the wiring be diffrent, many thanks
vward
pa4ul
Member - Posts: 15
Posted: August 27, 2009 at 3:41 PM / IP Logged
y not just order a hid kit. pm me if u wanna know where to get em cheap.
vincewrd
Posted: August 28, 2009 at 7:14 AM / IP Logged
because they dont last long and these lights i have are original bmw xenon light 600 pound each so i wanted to use the real ones, thanks any way
vward
vincewrd
Posted: August 28, 2009 at 7:18 AM / IP Logged
bmw headlight change to zeon -- posted image.
i found this image and wondered if any one knew what the little plug is for on the ballast i think the bigger plug is the feed?
vward
pa4ul
Member - Posts: 15
Posted: September 23, 2009 at 5:16 PM / IP Logged
well i have an 03 audi and upgraded my fogs to match my lowbeam hids and they match perfect. Had them on for over 3 years now no problems. And my stock hids run about 1000 usd.
sciullo779
Member - Posts: 12
Posted: November 14, 2009 at 12:30 AM / IP Logged
"little plug" prolly goes to the halos if you have them, and personally i would think that the oem wiring would be different, and the headlight assembly might also be different
