flashing led strips
tim_daviesmoss
Posted: August 30, 2009 at 8:28 AM / IP Logged
please help...
i have fitted 2 x 24cm LED strips to the front of my bumper linked direct to my headlights
i am told that they are pulsing because of the fault detection system... how can i stop the pulsing when the ignition is off
there fine when the lights are on
im sligtly aware i might need a resistor but what size and where do you get them ?
tim
Platinum - Posts: 13,725
Posted: August 30, 2009 at 10:09 AM / IP Logged
It would really help if we knew exactly how you have the LEDs connected.  What kind of a vehicle would help lots too.
tim_daviesmoss
Posted: August 30, 2009 at 10:10 AM / IP Logged
Its a vauxhaul Vectra ... yr 2007
the LEDs are connected streight to the headlight bulb to come on with the lights
Posted: August 30, 2009 at 10:46 AM / IP Logged
Are the LEDs grounded and are getting power from the headlight bulb?   Have you checked with a volt meter to see what kind of voltage there is on the headlamp bulb when the key is off?   How many wires are there on the LEDs?  What are the functions of the wires?
tim_daviesmoss
Posted: August 30, 2009 at 11:24 AM / IP Logged
Its not grounded as there are only 2 wires... dirrect to the two headlight bulb connectors
2 wires in the LEDs
as for the other questions... iv no idea... im not that good with anything lower than house electrics
Posted: September 02, 2009 at 6:00 AM / IP Logged
Are both headlight bulb connectors on the same bulb?  Is the headlight a dual element bulb?   Try grounding the black wire of the LEDs to the chassis of the vehicle.  And connect only the positive wire to the headlight.
tim_daviesmoss
Posted: September 02, 2009 at 8:38 AM / IP Logged
Not a duel eliment bulb and both connectors are the same size... i will try your idea.. thank you
i know the pulsing is the headlight testing system that checks for blown bulbs so maybe your idea will work
thank you
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
