capacitor wiring to dim light
henry_shadowjet
Posted: November 08, 2010 at 1:28 AM / IP Logged
Hi all,
I just have a question, this should be simple but it's just doing my head in. If you want to make a light circuit to slowly dim when the switch is turned off with a capacitor, how do you do the wiring?
A wiring diagram would be really appreciated.
Thank you very much in advance for your time and attention.
Cheers!
One day I will become the most powerful Jedi ever... One that could even stop people from dying!
oldspark
Gold - Posts: 4,913
Posted: November 08, 2010 at 1:38 AM / IP Logged
Wire the capacitor in parallel with the light.
The capacitor discharges thru the light when the power is switched off.
The "time constant" t = RC seconds where R = resistance of the light & C = capacitance (Ohms, Farads, seconds) and t is the time to discharge about 2/3rds of the voltage (ie, to 1/3 voltage remaining).
henry_shadowjet
Posted: November 08, 2010 at 1:52 AM / IP Logged
hi there!
Thanks for replying so quickly! Much appreciated.
I'm just wondering about the theory of it, not to question your solution or anything. If capacitor "stores" electricity, why can't it be wired in series with the light?
Such as:
(battery +) --> (capacitor) --> (light) --> (battery -)
oldspark
Gold - Posts: 4,913
Posted: November 08, 2010 at 5:19 AM / IP Logged
Think of it as the capacitor is the battery once the power source is disconnected.
(Is a capacitor ACROSS a load in series or parallel if they are the only components? Same for a battery and light. But put a battery and capacitor and light in series, and DC current will NOT flow... IE - the lamp will light but dim as the capacitor charges.)
henry_shadowjet
Posted: November 08, 2010 at 5:48 AM / IP Logged
I think I'm beginning to get it. Thanks a lot :)
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
