Posted: October 02, 2014 at 12:05 AM / IP Logged
Posted: October 02, 2014 at 2:08 AM / IP Logged
Posted: October 02, 2014 at 9:40 AM / IP Logged
Posted: October 02, 2014 at 6:02 PM / IP Logged
Saturday, March 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
They are usually described as a 3 position SPDT ON-OFF-ON or Single Pole ON/OFF/ON.
You can get larger versions, some with spade terminals to avoid the need to solder.
The centre terminal goes to the +ve end of your LEDs whose other end goes to ground. BUT that assumes one side of your speaker or amp output is grounded, if it isn't you need different wiring and a DPDT or Double Pole ON/OFF/ON equivalent like:
(Thanks to
