LED bullet light wiring
skyjacker03
Posted: July 05, 2015 at 8:44 PM / IP Logged Link to Post Post Reply Quote skyjacker03
Hi-
I have some LED bullet lights that I want to wire in a project. I want to use them as running lights, brake lights, and turn signals. They have 3 wires going to them. I saw some similar topics but not one exactly for what I'm looking to do.
Thanks in advance,
Joe
the12volt
Administrator - Posts: 3,957
Posted: July 06, 2015 at 7:24 AM / IP Logged Link to Post Post Reply Quote the12volt
Are the three wires black, blue, and red? If so, black is ground, blue is 12v+ dim (parking and/or running input), red is 12V+ bright (brake and turn signal input).
LED bullet light wiring -- posted image. the12volt • Support the12volt.com
skyjacker03
Posted: July 06, 2015 at 2:58 PM / IP Logged Link to Post Post Reply Quote skyjacker03
I will have to verify the colors. I just know their are 3 wires.
Here is a link to the lights
http://pages./link/?nav=item.view&alt=web&id=361205972349&globalID=EBAY-US
Do I need any diodes or resistors? If so please let me know what size/rating I need.
Thanks,
Joe
skyjacker03
Posted: July 06, 2015 at 3:15 PM / IP Logged Link to Post Post Reply Quote skyjacker03
The link doesn't appear to be working. The pic shows a red, white, and black wire.
the12volt
Posted: July 06, 2015 at 3:47 PM / IP Logged Link to Post Post Reply Quote the12volt
I pulled up a few ebay listings with the ID number. All the descriptions say it's a 12V light, so you shouldn't need any resistors, nor will you need any diodes. I'd test it on the bench first before making any permanent connections, but my guess would be black is ground, white is 12v+ dim, and red is 12V+ bright. You can use a plain 9V battery to test it for convenience.
skyjacker03
Posted: July 06, 2015 at 4:00 PM / IP Logged Link to Post Post Reply Quote skyjacker03
That's great! I'll get a battery. I guess I can't test the turn signals? Most of the write ups that I saw guys are using resistors or the lights hyper blink. I am not sure what brand and or rating lamps they are using.
Wednesday, October 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
