Polar bear many lights
patineto
Member - Posts: 12
Posted: December 21, 2016 at 12:42 AM / IP Logged Link to Post Post Reply Quote patineto
Okay we just got a 2000 landcruiser, the stock lights are not even dull..
So here is what I want to install (not all to be run at the same time, doh...)
Wake board spoiler, hella 3000 fully adjustable spots.
Polar bear many lights -- posted image.
The seat on the rack flat like this..
Working...
Also a 42'' half spot, half float led light bar.
Then two awesome borg Wagner H4 HID 955W 4000K BEST LIGHTS EVER.
patineto
Member - Posts: 12
Posted: December 21, 2016 at 12:48 AM / IP Logged Link to Post Post Reply Quote patineto
Sorry horrible first posting..
The wakenboard looks like this.
Then uon the back side of the grill four of this.cubes.no green lenses.
To make that happen, I made my own grill.
patineto
Member - Posts: 12
Posted: December 21, 2016 at 12:58 AM / IP Logged Link to Post Post Reply Quote patineto
And to manage it all a left control pod from a BMW k1200lt., with every button you can think and perfect ergonomics.
No my problem is that I have no idea how to make them work in ''combos''..
6all fog lights, all lower lihjt, all lights on high beam or low beam..
Well you are the master a little help please..
I have a blue sea with 6 relays and 12 positions, 6 On since with the key one...
Ricky
patineto
Member - Posts: 12
Posted: December 24, 2016 at 10:16 PM / IP Logged Link to Post Post Reply Quote patineto
Sorry this is convoluted, my brain is always comnuluted, i',m always thinking of ten projects at one..
Basically I find the location next to the gear shifter them most ergonomically efficient and that is the reason why I want to run the BMW control pod next to it, so is always at east right from my right hand 9i'm a right hand prominent, the land cruiser is automatic..
I'm also have problems with the relay on my blue sea box ( and I read and read)
Help or at like some links will be wonderful.
patineto
Member - Posts: 12
Posted: December 24, 2016 at 10:32 PM / IP Logged Link to Post Post Reply Quote patineto
The control pod will be located about a inch away from the reverse lock out button (is mechanical, very hard to relocate)
The angle will be about 10-15 degrees for baptismal reach, the pod work in a 'can-bus'' set up sincerely I only is not a massive problem in conparation to the old wire looms that work with conventional fuses..
patineto
Member - Posts: 12
Posted: December 25, 2016 at 3:45 PM / IP Logged Link to Post Post Reply Quote patineto
'Access denied". Hey I want to learn, how can I learn if I can not read the massive wisdom...///
Confused..
Saturday, June 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
